Harley Big Twin Chrome 41mm Fork Tube Set 20 Total Length - V-Twin 24-0400 - OEM 45950-48
Fork tube set is stock length and precision machined with ground finish for fit and quality. Before installing compare old and new tubes. Be sure the stock plugs fit into the new fork tubes. Sold as a pair. *NOTE: These are fork tubes only. Internal springs and top cap set are not included. Order internals separately. Fits 1949-1976 Harley Panhead and Shovelhead models.
OEM #: 45950-48
- Diameter: 41mm
- Length: 20 inches
- Drain assembly lube. We recommend 20 weight oil for average conditions. The amount of fork oil per leg is 6.5 ounces.
| 1949-1976 | FL |
