Harley Big Twin Black 18 Offset Spring Fork Assembly - V-Twin 49-2407 - OEM 45515-46
Unit features front and rear legs with a painted black finish inner and outer springs and rockers. For use with rigid frames with 30° rake. Includes offset outside mount rockers to utilize interchangeable wheel with lug bolt type drum studs and bushings and spring rods with bushings. Some assembly may be required. These forks are replicas of the stock units with electric welded and brazed construction and will accept all original style components and accessories for the detailed replica look. *Note: UPS may consider this part as packaged inchoversize inch for shipment as compared to the actual weight which will result in higher shipping costs. *NOTE: We measure from the top of the rear leg (tube) to the front axle center line. Installation instructions (PDF). Fits 1946-1948 Harley Flathead, Knucklehead, and Panhead models.
OEM #: 45515-46, 2601-46
- Neck Stem: 1 inches
- Length: 18 inches
- Between Rockers: 8 inches
- *NOTE: Must order shock ride control axle assembly top tree and bearing kit as required.
- How we measure Spring Forks. NOTE: Measurement is from the triple tree where stem and lower bearing sits to the axle position. This is the effective length as it is the length
- from the lower bearing cup on the frame to axle. Installer can slide a pipe or solid bar thru the bearing cups and measure the length that may be needed for the desired frame
- height. 1inch stem utilized tapered bearings for ease of installation.
| 1946-1948 | FL |
| 1946-1948 | UL |
