Harley 41mm Wide Glide Fork Assembly with Polished Sliders - V-Twin 24-0759 - Sportster 1952-1981
Wide glide fork assembly with polished sliders accept 11-1/2 inch single disc for 1952-1981 XL models. Fork assembly wide glide with polished sliders features wide style with triple trees axle neck bearings top cone and stem nut pinch bolts and bearing dust covers. Unit requires a Big Twin Wide Glide front wheel. Units do not include provision for fork locks. The length from the top of the fork tube to the center of the axle hole measures 31-5/8 inch. Fits 1952-1981 Harley Sportster models.
- Drain assembly lube. We recommend 20 weight oil for average conditions. The amount of fork oil per leg is 5.5 ounces.
- Suggested to use with Left Side Speedometer Drive Unit.
| 1952-1981 | XL |
