Harley Softail 41mm Narrow Tree Kit - V-Twin 24-1441 - Big Twin 1984-1999
41mm narrow glide kit features an upper and lower triple tree. Stock rake in alloy finish. 1 inch stem 3/4 inch axle and stem nut included. Top tree riser mount hole measure 3-1/2 inch center to center. Set fits 1984-99 Softail fork slider assemblies use 1984-99 Softail brake caliper. Order related components separately. Tree set will accept any 41mm right and left fork tube assembly with single or dual disc mounts. Set can also be used with 41mm single disc fork assemblies where the caliper is on the left side for 11 inch rotors. Installer must provide spacers and allow clearance for caliper to fit in the narrow width of the tree set. Center to center distance of fork tube is 180cm in triple tree set. FXD or XL front wheels with 3/4 inch axle can be fitted to your completed for assembly. *NOTE: In order for the set to fit with 11.5 inch rotors that are mounted on a single disc it will require a smaller custom caliper. Check spoke clearance and rim width that will fit 1.85 x 19 inch or 21 inch. Does not pop up. *NOTE: Depending on wheel hub it may require making axle spacers. Fits 1984-1999 Harley Softail models.
- *NOTE: All trees are machined from a forged billet (Hot forged) as opposed to cast
| 1984-1999 | FXST |
