Harley Shovelhead 41mm Glide Fork Slider Set Polished - V-Twin 24-1388
Polished right and left 41mm Glide fork slider set for the left side caliper. Lower leg set accepts 1977-1984 type seals. The tube fits directly into the leg without bushings. NOTE: Bushings included. Sold as set of two. *NOTE: Fork legs accept the later model double lip seal related seal washers and snap rings. Fits 1972-1977 Harley Shovelhead models.
- Suggested to use with Fork Seal Kit.
- Suggested to use with Hard Chrome 41mm Fork Tube Assembly 20-7/8inch Total Length
| 1972-1977 | FL |
