Harley Softail 41mm Fork Slider Assembly - V-Twin 24-9918 - OEM 46004-84 - Big Twin 1984-1999
Assembly features polished sliders with springs hard chrome fork tubes and components installed. Assembly is for a single disc application. Set of two. *NOTE: The length from the top of the fork tube to the center of the axle hole measures 31-5/8 inch. Fits 1984-1999 Harley Softail models.
OEM #: 46004-84, 46006-84
- Drain assembly lube. We recommend 20 weight oil for average conditions. The amount of fork oil per leg is 10.2 ounces.
| 1984-1999 | FXST |
