Harley Big Twin 41mm Fork Damper Valve - V-Twin 24-0361 - Twin Cam 2000-2015
Fork damper valve allows accurate damping of oil flow. Valve has an outer diameter of 31mm. 41MM fork tamper valve controls the motion with a tunable valve that sits on top of the damping rod. Fork damper valves are held in place by the main fork springs. Installation instructions (PDF). Fits 2000-2015 Harley Dyna, Softail, and Touring models.
| 2000-2015 | FLST |
| 2000-2013 | FLT |
| 2000-2005 | FXDWG |
| 2000-2015 | FXST |
