Harley Big Twin & Sportster 39mm Fork Tube Assembly Chrome - V-Twin 24-0107
39mm fork tube assembly features a hard chrome finish. Fork tubes measure 23-3/8 inch overall length with internal damper rods and assembled spring forks. Top caps are included. Seal kit is supplied for lower sliders. Assembly includes fork tube plugs without hole spring set damper kit seal set 39mm fork dust lower seal fork slider bushing set and 39mm fork plug o-ring. Sold as a pair. Order upper fork bushings separately. *NOTE: Will not fit XL Hug (hugger) or (C) custom models. Fits 1987-1999 Harley FXR and Sportster models.
- Drain assembly lube. We recommend 20 weight oil for average conditions.
- Suggested to use with 39mm Fork Slider Upper Bushing Set.
| 1988-1994 | FXR |
| 1987-1999 | XL |
