Harley Big Twin & Sportster 33.4mm Fork Damper Tube Kit - V-Twin 24-0454 - Ironhead 1968-1972
SKU 24-0454
$189.99
1899 ENTRIES 🎟️
$189.99 - $189.99
$189.99
1899 ENTRIES 🎟️
Damper kit with steel legs includes damper tubes with rings screws washers lower stops slider seal washers and retaining rings for both sides. Order stock hard chrome fork tubes piston damper set springs and quantity two of top plugs to convert early 1952-1970 steel legs. *NOTE: Technician may be required to drill the steel lower legs on 1952-1970 K and XL models to accept a larger damper bolt Hard Chrome tubes and springs. Fits 1968-1972 Harley Sportster and Shovelhead models.
  • Length: 11 inches
  • Suggested to use with Hard Chrome 33.4mm Fork Tube Set 22-3/4inch total length.
  • Suggested to use with 33.4mm Fork Tube Spring Set.
  • Suggested to use with #7621-1 Chrome Fork Tube Cap.
1971-1972 FX
1968-1972 XL
