Harley 22 Tedd Narrow Spring Fork Assembly Black - V-Twin 49-3125
22 inch Tedd narrow Spring Fork assembly unit features a black finish with chrome springs. Spring Fork developed over a 2 year period original look but narrow! Detailed construction with the intricate details of the factory! Includes the triple tree 1 inch stem brake boss and a 3/4 inch axle. The top triple tree features standard stem and tube locations and is inline so to accept dog bone or stock Spring Fork handlebars. The width between the rocker width is 6 inch. *NOTE: Will accept original Spring Fork components headlamp bracket shock assembly or ride control as it includes original fittings! The distance between the rockers measure 6 inch and the axle has an outer diameter of 3/4 inch. The legs are drilled and tapped 3/4 inch-18 for mounting risers. *NOTE: Left side rocker is offset to allow space for applications where a brake system is installed. Universal fit for most Harley applications.
