Harley Big Twin 18 Spring Fork Kit Black - V-Twin 24-1570
18 inch Spring Fork kit is black with chrome springs. Top triple tree is machined chrome design without ears. Use post risers with stud to top of rear fork legs. Legs thread are 1/2 inch x 20. Includes 1 inch fork stem and 3/4 inch axle assembly. The rockers are the same as the OEM (right rocker is NOT offset) for custom brake and spool wheel installation. 1 inch taper bearing kit available separately. Spring Fork has original shape components and design. For the most accurate replica choose one of our replica Spring Forks over 20 000 sold since 1994! *NOTE: Use spacers for axle as required to center wheel. Installation instructions (PDF). Fits 1936-2017 Harley Big Twin, FX (Super Glide), Softail, Knucklehead, Panhead, and Shovelhead models.
- Suggested to use with 1inch Taper Bearing Neck Conversion Kit
| 1936-1952 | EL |
| 1941-1984 | FL |
| 1986-2017 | FLST |
| 1970-1984 | FX |
| 1986-2017 | FXST |
