Harley Big Twin 18 Offset Spring Fork Assembly Chrome - V-Twin 49-2412
Unit features chrome front legs outer springs rockers and chrome rear leg. For use with rigid frames with 30° rake. Includes inner and outer springs front and rear legs offset outside mount rockers to utilize interchangeable wheel with lug bolt type drum studs and bushings spring rods with bushings. Some assembly may be required. These forks are replicas of the stock units with electric welded and brazed construction and will accept all original style components and accessories for the detailed replica look. Unit is unpolished at the rear fork stem cross plate and at the front spring fork rod forging. *NOTE: We measure from the top of the rear leg (tube) to the front axle center line. Installation instructions (PDF). Fits 1946-1948 Harley Knucklehead and Panhead models.
- Length: 18 inches
- Suggested to use with Front Axle Kit.
- *NOTE: Must order shock ride control axle assembly top tree and bearing kit as required.
- How we measure Spring Forks. NOTE: Measurement is from the triple tree where stem and lower bearing sits to the axle position. This is the effective length as it is the legnth
- from the lower bearing cup on the frame to axle. Installer can slide a pipe or solid bar thru the bearing cups and measure the length that may be needed for the desired frame
- height. 1inch stem utilized tapered bearings for ease of installation.
| 1946-1948 | FL |
