Raw Machined Steel 41mm Fork Tube Set with 20 Total Length - V-Twin 24-0024 - OEM 45950-48
SKU 24-0024
$159.99
$159.99
$159.99
$159.99
$159.99
$159.99
OEM #: 45950-48
Raw machined steel fork tube is 20 inch stock length.
Before installing compare old and new tubes. Be sure the stock top plug threads fit into the new fork tubes. Sold as a pair. *NOTE: These are fork tubes only. Order internals separately.
- Diameter: 41mm
- Length: 20 inches
- Drain assembly lube. We recommend 20 weight oil for average conditions. The amount of fork oil per leg is 6.5 ounces.
| 1949-1976 | FL |
