Standard Pedal Set - V-Twin 49-1683
Standard pedal set is Torrington type with 1 right and 1 left hand nickel plated pedals with the standard pedal rubber set installed.
Real rubber museum quality as used on Motorcycepedia restorations by Bruce Linsday! The kick starter pedal rod nuts are from McMaster-Carr. *NOTE: The center axle is heat treated and un-plated.
- Threads: 1/2 inches -20
- Suggested to use with #49-1683A Zinc Plated Hex Nut.
| 0 | All |
