FXR Brake Pedal Polished Alloy - V-Twin 23-0139 - OEM 42523-82 - Big Twin 1982-1994
SKU 23-0139
$159.99
$159.99 - $159.99
$159.99
OEM #: 42523-82, 42523-87
FXR brake pedal has a polished alloy finish and includes the bushings installed.
*NOTE: Must order rod end wave washer cotter pin and the master cylinder which icludes the piston rod installed separately. *NOTE: Includes the clevis with pin. *NOTE: For FXR mid control applications.
  • Required to use with #23-1986 Brake Rod Plunger End.
  • Suggested to use with Rear Remote Mount Master Cylinder Chrome.
  • Suggested to use with FXR Rear Brake Clevis Zinc Plated which is the short piston rod.
  • Suggested to use with FXR Pedal Rod End Kit Zinc Plated which is the long piston rod.
1982-1994 FXR
