Harley Big Twin Rocker Clutch Pedal Assembly Parkerized - V-Twin 22-0874
SKU 22-0874
$249.99
2499 ENTRIES 🎟️
$249.99 - $249.99
$249.99
2499 ENTRIES 🎟️
Includes mount bracket with bushings installed pedal spring black friction cover and all friction components. *NOTE: Must order the rod separately. *NOTE: Can also be used on 1952-1984 Big Twin models when converting to handshift. 1971-1984 models will also require spacer V-Twin. 1965-1978 models will also require V-Twin clutch release lever. *NOTE: Inner arm position for use with aluminum primay covers. Spacer required behind rocker clutch assembly as shown. Includes foot clutch rod lever with offset. Fits 1941-1964 Harley Knucklehead and Panhead models.
1941-1964 FL
