Harley Big Twin Rocker Clutch Assembly - V-Twin 22-1675
SKU 22-1675
$249.99
2499 ENTRIES 🎟️
$249.99 - $249.99
$249.99
2499 ENTRIES 🎟️
Parkerized rocker clutch assembly includes mount bracket with bushing installed spring cover and all friction components. Order correct clutch pull rod separately. Clutch pull rod connects to the pin riveted to the inside of the pedal. Order clutch pull rod separately. For exact restoration on 1936-1938 models. Measurements heel to toe are 9-1/8 inch pedal shaft measures 1.690 inch in length. Fits 1938-1939 Harley Flathead and Knucklehead models.
  • Heel To Toe: 9-1/8 inches
  • Pedal Shaft Length: 1.690 inches
  • Bracket Length: 9-7/8 inches
1938-1939 EL
1938-1939 UL
