Harley Big Twin Rocker Clutch Assembly Parkerized - V-Twin 22-0463
SKU 22-0463
$249.99
2499 ENTRIES 🎟️
$249.99 - $249.99
$249.99
2499 ENTRIES 🎟️
Parkerized rocker clutch assembly is fully assembled. Includes hex mount bolts clutch rod end and bolts and an oval rubber pad set packed inside of a 5 gallon oil can. *NOTE: When used on models with an aluminum primary a forward control frame left side spacer is required. Clutch is released in the forward position. Order clutch rod separately. Fits 1938-1939 Harley Flathead and Knucklehead models.
  • Required to use with Forward Control Frame Spacer Left Side when used on models with an aluminum primary.
1938-1939 EL
1938-1939 UL
