Harley Prism Sling Shot Brake Pedal Assembly Natural Stainless - Prism CON023SS - Big Twin 0+
Prism mechanical brake pedal assembly features a natural stainless steel finish. For use on rigid frame models with a mechanical brake cross shaft tube and brake rod. Includes both the forward and backward internal lever stops. All necessary mounting hardware is included to bolt directly to the frame. For shorter reach the forward brake and jockey pedal can be used with mid-footpegs. Universal fit for most Harley applications.
Prism #: CON023SS
