Harley Big Twin Lee Style Jockey Clutch Pedal - V-Twin 21-0932
SKU 21-0932
$139.99
1399 ENTRIES 🎟️
$139.99 - $139.99
$139.99
1399 ENTRIES 🎟️
Chrome pedal and cast bracket attaches to the OE style mount plate for foot clutch operation. The inner shifter arm is removable from the pedal shaft. For use with original Jockey Pedal Brackets from 1941-65 FL's. The Lee Style Jockey Pedal will bolt to this original bracket with hardware included. Requires use of a hand shift kit. Jockey pedal is designed to fit a stock rocker clutch bracket which is available separately. On 45 Solo models the inchLee inch unit may be fitted to the stock rocker clutch assembly. Clutch pull rod must be fabricated for each application. NOTE: Use aa 3/8 inch x 24 inch x 2-1/2 inch oval head screws for mounting for an authentic look! Pay attention to the details. Fits 1936-1984 Harley Big Twin, FX (Super Glide), Flathead, Knucklehead, Panhead, and Shovelhead models.
1936-1952 EL
1941-1984 FL
1971-1984 FX
1936-1948 U
