Harley Daniel Boone Forward Control Kit - V-Twin 22-0714 - Big Twin 1958-1999
Daniel Boone chrome brake control kit fits all hydraulic brake models with disc brakes for rigid or swingarm frames. Includes correct linkage for 4 speed 1979-1984 rotary top models. Accepts Kelsey Hayes type master cylinder not included. Mounts to frame with 3/8 x 16 inch hex bolts. Order rear 3/8 inch bore master cylinder and hex bolts separately. Include right hand brake and left hand shift assembly. For ratchet top order rod separately. *Note: UPS may consider this part as packaged inchoversize inch for shipment as compared to the actual weight which will result in higher shipping costs. Fits 1958-1999 Harley Big Twin, FX (Super Glide), Softail, Panhead, and Shovelhead models.
- Rod End: 1-13/16 inches
- Suggested to use with Rear Master Cylinder 3/4inch Bore Chrome.
- Suggested to use with Front or Rear Brake Caliper Piston
| 1958-1984 | FL |
| 1971-1984 | FX |
| 1985-1999 | FXST |
