Harley Chrome Jockey Clutch Pedal and Plate - V-Twin 21-0102
Clutch pedal and plate for ratchet or jockey top features a chrome finish. Forward hole is for the footpeg or footboard stud. Pedal features a stud which will accept cotter pins to attach to the rod end. Uses standard clutch pull rod and lollypop end. *NOTE: Clutch release lever clears alloy primary on 1965-78 for mounsetrap or police jockey clutch. Eliminator clutch arm is for installing a mousetrap eliminator cable on 1936-78 clears wrap around oil tank. Universal fit for most Harley applications.
- Suggested to use with pedal with top
