Harley Big Twin Chrome Foot Clutch Assembly - V-Twin 22-0833
Chrome rocker style foot clutch assembly is for models with a ratchet top. Includes foot clutch rod lever with offset rocker pedal assembly pull rod and clutch arm. For aluminum primary application 4 speed models use order the following separately: clutch arm with rods pull rod rod ends spacer block and snap ring. For tin primary applications 1941-1984 FL and 1936-1952 EL rod can be connected by the foot lever clutch pin directly to the pedal. Fits 1965-1978 Harley Panhead and Shovelhead models.
- Suggested to use with Clutch Release Lever.
- Suggested to use with Foot Clutch Lever Rod Cadmium.
- Suggested to use with Foot Clutch Lever Rod Chrome.
- Suggested to use with Foot Clutch Pull Rod End Cadmium.
- Suggested to use with Foot Clutch Pull Rod End Chrome.
- Suggested to use with Foot Clutch Rod End Snap Ring.
- Suggested to use with Forward Control Frame Spacer Left Side.
| 1965-1978 | FL |
