Harley Billet Forward Control Kit Extended - V-Twin 22-0755 - Big Twin 0+
Chrome billet 2 inch extended forward control kit features a 3/4 inch master cylinder bore. Includes left and right sides complete with master cylinder and rubber belted pegs. Order shifter rod and stainless steel brake line separately. The mount hole spacing measures 2 inch on brake side and 1-1/4 inch on shift side. Use with DOT 5 brake fluid. **NOTE: When installing extended forward controls on a motorcycle make sure all clearances are checked. *Note: UPS may consider this part as packaged inchoversize inch for shipment as compared to the actual weight which will result in higher shipping costs. Universal fit for most Harley applications.
- Suggested to use with Brake Pedal Pad Pirate Style.
- Suggested to use with Brake Hose Adapter Fitting 35°.
- Suggested to use with Stainless Steel Brake Hose 32inch.
- Suggested to use with Chrome Billet Rear Brake Tee.
- Suggested to use with Brake Hose Adapter Fittings.
- Suggested to use with Stainless Steel Brake Hose 12inch.
- Suggested to use with Brake Hose Adapter Fitting.
- Suggested to use with Rear Master Cylinder Rebuild (3/4inch).
- Suggested to use with Chrome Kickstand Mount Kit.
- For 1986-99 Softails use Slotted Shifter Rod Assembly.
