Harley Big Twin AEE Jockey Clutch Pedal Kit Stainless Steel - V-Twin 21-0026
by AEE
SKU 21-0026
$189.99
1899 ENTRIES 🎟️
$189.99 - $189.99
$189.99
1899 ENTRIES 🎟️
AEE jockey clutch pedal kit includes pedal and plate. For use with mid footpeg set. Features a stainless steel finish. Stock kickstand assembly may be re-installed. *NOTE: Must order clutch pull rod separately by length required by the clutch arm installed. For shorter reach the forward brake and jockey pedal can be used with mid-footpegs. *NOTE: Pedal includes a square rubber pad attached by a 1/4 inch stud. Fits 1941-1984 Harley Big Twin, Knucklehead, Panhead, and Shovelhead models.
1941-1984 FL
