Black Rocker Clutch Pedal Assembly - V-Twin 22-1016 - OEM 36810-65A
OEM #: 36810-65A
Includes mount bracket with bushings installed pedal spring cover and all friction components.
The clutch pull rod connects to the arm on the pivot shaft. *NOTE: The rod must be ordered separately. *NOTE: Can also be used on 1952-1984 Big Twin models when converting to handshift. 1971-1984 models will also require spacer V-Twin. 1965-1978 models will also require V-Twin clutch release lever. *NOTE: Inner arm position for use with aluminum primay covers. Spacer required behind rocker clutch assembly as shown. Includes foot clutch rod lever with offset. For tin primary applications 1941-1984 FL and 1936-1952 EL rod can be connected by the foot lever clutch pin directly to the pedal.
- Suggested to use with Foot Clutch Lever Rod Parkerized.
| 1940-1984 | FL |
