Harley Big Twin Zinc Hydraulic Brake Control Kit - V-Twin 22-0747
Zinc brake control kit — pedal and the mounting hardware needed to run a hydraulic rear brake — a direct replacement for a worn-out or missing factory control setup. Fits 1958-1969 Harley Panhead and Shovelhead models.
Hydraulic brake control kit features all zinc plated components except the spring which is black.
Requires footboard mount kit to install footboards on forward brake kits.
- Required to use with Replica Footboard Mount Bracket Kit Black.
| 1958-1969 | FL |
