Harley Big Twin Hydraulic Brake Control Kit - V-Twin 22-0403
SKU 22-0403
$309.99
3099 ENTRIES 🎟️
$309.99 - $309.99
$309.99
3099 ENTRIES 🎟️
Brake control kit — pedal and the mounting hardware needed to run a hydraulic rear brake — a direct replacement for a worn-out or missing factory control setup. Fits 1958-1969 Harley Panhead and Shovelhead models.
Hydraulic brake control kit has a chrome master cylinder chrome brake pedal spring plunger assembly clevis pin mount plate master cylinder spacers bolts nuts and washers.
Requires footboard mount kit to install footboards on forward brake kits.
  • Required to use with Replica Footboard Mount Bracket Kit Black.
1958-1969 FL
