Harley Shovelhead Forward Hydraulic Brake Control Kit - V-Twin 22-0501
SKU 22-0501
$159.99
1599 ENTRIES 🎟️
$159.99 - $159.99
$159.99
1599 ENTRIES 🎟️
Forward brake control kit — pedal and the mounting hardware needed to run a hydraulic rear brake — a direct replacement for a worn-out or missing factory control setup. Fits 1979-1982 Harley Shovelhead models.
Kit is equipped for models powered by Shovelhead engines with hydraulic brake systems.
Includes mount plate brake pedal spring brake line support foot brake pedal plunger clevis pin Kelsey Hayes foot peg mount stud master cylinder mount stud master cylinder spacers and hardware. Order master cylinder separately.
  • Suggested to use brake line on front for FXST Suggested to use rear brake line. Suggested to use brake tee.
1979-1982 FL
