Harley Shovelhead Forward Control Kit Hydraulic - V-Twin 22-1017
Forward brake control kit — pedal and the mounting hardware needed to run a hydraulic rear brake — a direct replacement for a worn-out or missing factory control setup. Fits 1979-1982 Harley Shovelhead models.
Kit is equipped for models powered by Shovelhead engines with hydraulic brake system.
Includes brake pedal spring brake line support foot brake pedal and plunger Kelsey Hayes foot peg mount stud Kelsey Hayes 3/4 inch bore master cylinder master cylinder mount stud plunger pin and master cylinder spacer.
- For FXST application we suggest you use or brake hose and brake line tee.
| 1979-1982 | FL |
