Harley Shovelhead Forward Brake Control Kit Hydraulic - V-Twin 22-0506
SKU 22-0506
$299.99
2999 ENTRIES 🎟️
$299.99 - $299.99
$299.99
2999 ENTRIES 🎟️
Forward brake control kit — pedal and the mounting hardware needed to run a hydraulic rear brake — a direct replacement for a worn-out or missing factory control setup. Fits 1970-1978 Harley Shovelhead models.
Kit is equipped for models powered by Shovelhead or Evolution engines and with hydraulic brake system.
Includes brake pedal pedal stop plate brake line support bracket a Wagner style master cylinder master cylinder spacer brake pedal plunger clevis p ns clutch finger shaft washer. Footboards can be fitted to this kit.
  • Suggested to use with front line stainless steel Suggested to use with rear line stainless steel Suggested to use with brake tee
1970-1978 FL
