Harley Shovelhead Forward Brake Control Kit Hydraulic - V-Twin 22-0500
Forward brake control kit — pedal and the mounting hardware needed to run a hydraulic rear brake — a direct replacement for a worn-out or missing factory control setup. Fits 1970-1978 Harley Shovelhead models.
Kit is equipped for models powered by Shovelhead or Evolution engines and with hydraulic brake system.
Includes brake pedal pedal stop plate brake line support bracket master cylinder spacer brake pedal plunger clevis pins and pedal mounting plate. Footboards can be fitted to this kit.
- Suggested to use brake hose on the front for FXST. Suggested to use rear brake hose for disc brake. Suggested to use brake tee.
| 1970-1978 | FL |
