Harley Chrome Replica Forward Brake Control Kit - V-Twin 22-1066 - Big Twin 0+
SKU 22-1066
$229.99
2299 ENTRIES 🎟️
$229.99 - $229.99
$229.99
2299 ENTRIES 🎟️
Chrome Forward brake control kit — pedal and the mounting hardware needed to run a mechanical rear brake — a direct replacement for a worn-out or missing factory control setup. Universal fit for most Harley mechanical brake control setups.
Replica kit includes linkage pedal mount plate and rubber covered footpegs.
Can be uses with either a Wagner or Kelsey Hayes master cylinder for disc brake models. Order master cylinder separately. Suggested to use with brake spring stud that features a 5/16 x 18 thread;. *Note: UPS may consider this part as packaged inchoversize inch for shipment as compared to the actual weight which will result in higher shipping costs.
  • Suggested to use with Rear Master Cylinder.
  • Suggested to use with Rear Disc Brake Master Cylinder.
  • Suggested to use with Brake Spring Stud which features a 5/16 x 18 thread.
