Harley Chrome Replica Forward Brake Control Kit - V-Twin 22-1018 - Big Twin 0+
Chrome Forward brake control kit — pedal and the mounting hardware needed to run a mechanical rear brake — a direct replacement for a worn-out or missing factory control setup. Universal fit for most Harley mechanical brake control setups.
Replica chrome forward control brake kit is FXST style and includes a Wagner master cylinder.
Replica chrome FXST style brake control kit includes Wagner master cylinder linkage pedal plate rubber footpeg and utilizes braided stainless steel lines from junction to rear caliper. Kit is for use on 1970-1999 Big Twin models with Shovelhead or Evolution engines equipped with hydraulic or mechanical type brakes. It is designed to place the driver peg in back of the brake pedal so the brake is easier to operate.
- Use rear brake hose (front line)
- Use rear brake hose to go from junction to the rear caliper.
- Use brake tee.
- Suggested to use with brake pedal
- Suggested to use with brake pedal spring.
- Suggested to use with Rear Master Cylinder Rebuild Kit.
