Harley Chrome Replica Forward Brake Control Kit - V-Twin 22-1001 - Big Twin 0+
SKU 22-1001
$349.99
3499 ENTRIES 🎟️
$349.99 - $349.99
$349.99
3499 ENTRIES 🎟️
Chrome Forward brake control kit — pedal and the mounting hardware needed to run a mechanical rear brake — a direct replacement for a worn-out or missing factory control setup. Universal fit for most Harley mechanical brake control setups.
Replica chrome FXST style brake control kit includes Kelsey- Hayes master cylinder linkage pedal plate and a rubber footpeg.
Replica forward brake control kit is for use on 1970-1999 Big Twin models with Shovelhead or Evolution engines equipped with hydraulic or mechanical brakes. It is designed to place the driver peg in back of the brake pedal so the brake is easier to operate from this comfortable position. It includes a Kelsey-Hayes master cylinder linkage pedal mount plate and rubber covered footpegs. Suggested to use with brake spring stud that features a 5/16 x 18 thread;. *NOTE: Suggested to use with D.O.T 4 brake fluid. *Note: UPS may consider this part as packaged inchoversize inch for shipment as compared to the actual weight which will result in higher shipping costs.
  • Suggested to use with Brake Spring Stud which features a 5/16 x 18 thread.
