Harley Big Twin Brake Control Kit Mechanical - V-Twin 22-0707
Brake control kit — pedal and the mounting hardware needed to run a mechanical rear brake — a direct replacement for a worn-out or missing factory control setup. Fits 1936-1957 Harley Flathead, Knucklehead, and Panhead models.
Parkerized brake control kit for use with mechanical brake frames with a cross shaft tube only. Footboards may be used with this kit.
On 1936-1957 Big Twins the rear brake lever arm faces rearward and in. *Note: UPS may consider this part as packaged inchoversize inch for shipment as compared to the actual weight which will result in higher shipping costs.
| 1936-1940 | EL |
| 1941-1957 | FL |
| 1936-1948 | UL |
