Harley Big Twin Brake Control Kit Mechanical - V-Twin 22-0706
SKU 22-0706
$279.99
2799 ENTRIES 🎟️
$279.99 - $279.99
$279.99
2799 ENTRIES 🎟️
Brake control kit — pedal and the mounting hardware needed to run a mechanical rear brake — a direct replacement for a worn-out or missing factory control setup. Fits 1936-1957 Harley Flathead, Knucklehead, and Panhead models.
Chrome brake control kit for mechanical brake frames with a cross shaft tube only. Footboards may be used with this kit.
Must order the clutch cable separately. NOTE: On 1936-1957 Big Twins the rear brake lever arm faces rearward and in. *Note: UPS may consider this part as packaged inchoversize inch for shipment as compared to the actual weight which will result in higher shipping costs.
  • Suggested to use with Black Clutch Cable.
1936-1940 EL
1941-1957 FL
1936-1948 UL
