Harley Flathead Spring Fork Front Fender - Wyatt Gatling 50-0523 POPEYE
SKU 50-0523
$269.99
2699 ENTRIES 🎟️
$269.99 - $269.99
$269.99
2699 ENTRIES 🎟️
Spring fork-style front fender, a direct replacement for a dented, rusted, or missing stock fender. Fits 1936-1952 Harley Flathead models.
Wyatt Gatling #: 50-0523 POPEYE
Spring fork front fender is for 16 inch or 18 inch wheels. The fender body is one piece with riveted on 5/8 inch narrow braces. Axle plate mounts are 9-1/2 inch wide at the inside surfaces. Fender features a raw finish.
Fender fits forks with inside mounted rockers on 45 solo models 1936-1952. Before priming or painting fit the fender body braces and mounting points in place. Fender rivets hinge and brackets will have to be tweaked for final fitment. Patience is required for proper installation! *Note: UPS may consider this part as packaged inchoversize inch for shipment as compared to the actual weight which will result in higher shipping costs.
  • Width: 7-1/4 inches
1936-1952 WL
