Harley Flathead Spring Fork Front Fender - V-Twin 50-0778
Spring fork-style front fender, a direct replacement for a dented, rusted, or missing stock fender. Fits 1936-1952 Harley Flathead models.
Spring fork front fenders are 7-1/4 inch wide for 16 inch or 18 inch wheels. The fender body is one piece construction with riveted on 7/8 inch wide braces.
For use on models with 3/8 inch axle and rockers inside the Spring Fork for the 1/2 inch brake drum style wheel. Before priming or painting fit the fender body braces and mounting points in place. Fender rivets hinge and brackets will have to be tweaked for final fitment. Patience is required for proper installation! *Note: UPS may consider this part as packaged inchoversize inch for shipment as compared to the actual weight which will result in higher shipping costs.
- Width: 7-1/4 inches
- Length: 32 inches
| 1936-1952 | WL |
