Harley Flathead Military Front Fender - Wyatt Gatling 50-0772 POPEYE - OEM 3702-41
SKU 50-0772
$349.99
3499 ENTRIES 🎟️
$349.99 - $349.99
$349.99
3499 ENTRIES 🎟️
Front fender, a direct replacement for a dented, rusted, or missing stock fender. Fits 1937-1952 Harley Flathead models.
Wyatt Gatling #: 50-0772 POPEYE · OEM #: 3702-41
Skirtless front fender is a 1940 army style for 45 solo models with spring forks. Fender comes with braces that are 5/8 inch wide. Fender features a raw finish.
Hole closest to the front of fender measures 1-7/8 inch center to center and 18-3/4 inch from front the fender. Center hole measures 4-3/16 inch center to center and 25-1/2 inch from front of the fender. Before priming or painting fit the fender body braces and mounting points in place. Fender rivets hinge and brackets will have to be tweaked for final fitment. Patience is required for proper installation! *Note: UPS may consider this part as packaged inchoversize inch for shipment as compared to the actual weight which will result in higher shipping costs.
  • Width: 7-1/4 inches
1937-1952 WL
