Harley Panhead Sprocket Shaft Spacer.336 - V-Twin 10-8269
SKU 10-8269
Sold out
249 ENTRIES 🎟️
249 ENTRIES 🎟️
Sprocket shaft spacer is.336 long and fit between Timken bearing assembly and the motor sprocket and are sealed. This spacer is a special spacer that fits into the engine seal when it is used on STD case sets. Fits 1955-1964 Harley Panhead models.
  • Length:.335 inches
  • Suggested to use with engine seal when using spacer on STD cases.
1955-1964 FL
