S&S Engine 6° Taper Sprocket Shaft - S&S Cycle 33-2004
by S&S Cycle
$169.99
$169.99
$169.99
1359 ENTRIES 🎟️
$169.99
$169.99
$169.99
1359 ENTRIES 🎟️
S&S Cycle #: 33-2004
Shaft is machined and hardened to factory specifications. Includes nut and key. Shaft is designed to fit late model type flywheels with a 6° taper.
For use in S&S SE or SL flywheels only.
- Suggested to use with Replica 3.968inch Stroke Flywheel Set.
| 0 | Replacement |
