Harley Panhead Replica Cast Iron Oil Pump Assembly - V-Twin 12-9931 - OEM 26201-48D
Replica cast iron oil pump assembly includes the correct oil pressure switch. Assembly is exact for the years listed! Outer cover is die cast as original for accurate restoration details. **NOTE: The oil pump flow rate is the same as stock flow. *NOTE: Welch plug is used to seal oil diffuser plate installation. See details in related photos. Fits 1949-1954 Harley Panhead models.
OEM #: 26201-48D
- Suggested to use with Engine case.619 Welch Plug.
| 1949-1954 | FL |
