Harley Big Twin Replica Cast Iron Oil Pump Assembly - V-Twin 12-8888
SKU 12-8888
Original price $539.99 - Original price $539.99
$539.99
5399 ENTRIES 🎟️
$539.99 - $539.99
$539.99
5399 ENTRIES 🎟️
Replica cast iron oil pump assembly. Includes all components completely assembled with the correct plugs fittings die cast alloy cover and pressure switch. Outer cover is die cast as original for accurate restoration details. **NOTE: The oil pump flow rate is the same as stock flow. Includes the later model oil pressure as seen in the photo. *NOTE: Welch plug is used to seal oil diffuser plate installation. See details in related photos. Fits 1955-1967 Harley Panhead and Shovelhead models.
  • Suggested to use with Engine case.619 Welch Plug.
1955-1967 FL
