74 Flatside Shovelhead Long Block - V-Twin 10-1966
SKU 10-1966
Original price $7,489.99 - Original price $7,489.99
$7,489.99
74899 ENTRIES 🎟️
$7,489.99 - $7,489.99
$7,489.99
74899 ENTRIES 🎟️
Assembled and tested for oil pressure. Includes all components pictured. Assembly is for use with 1965-1969 FL transmissions.
Use with steel inner and outer primary covers. Manufacturer's Bill of Sale is supplied. Includes top mount and motor sprocket shaft. Long block fits 1965-1969 Big Twin transmissions that feature mid length main shaft. This can also fit 1941-1964 but will require the use of 1965-1969 transmissions. *NOTE: Must order carburetor and generator separately not included. Left engine cast does not accept cast aluminum inner primary cover.
  • °Polished Rocker Boxes °Polished Oil Pump °Zinc Auto Advance Distributor
  • °Bright Tappet Blocks °Chrome Pushrod Covers °Alloy Intake Manifold
  • °Stainless Manifold Clamps
1965-1969 FL
