Harley Flathead Connecting Rod Cage Set - V-Twin 10-8753
SKU 10-8753
$74.99
749 ENTRIES 🎟️
$74.99 - $74.99
$74.99
749 ENTRIES 🎟️
Steel rod bearing cage set for WR model crank pins. Set of four cages. For use on a 1.38 inch (34.8mm) narrowed 1957-85 type narrowed Sportster rod set. Each case is.3425 inch wide. Requires the use of two short and one long roller set will accepts.6692 inch long roller and.2582 inch short roller. Rollers not included must order separately. *NOTE: Conversion utilizes Sportster 1957-1985 rod set. Fits 1936-1973 Harley Flathead models.
  • Suggested to use with 3-Hole Crank Pin.
  • Suggested to use with Connecting Rod Roller Set.
1936-1973 G
1936-1952 WR
