Harley Big Twin Ultima 8mm High Performance Spark Plug Wire Set Grey - Ultima 18-429 - Twin Cam 1999-2017
by Ultima
SKU 32-8429
$54.99
549 ENTRIES 🎟️
$54.99 - $54.99
$54.99
549 ENTRIES 🎟️
High performance 8mm wire-wound suppression core produces 300 ohms of resistance per foot. Equipped with the highest quality silicone spark plug boots and coil boots and double insulated at the spark plug and coil ends ready to install Wire set is a side mount which mounts to the coil behind the engine and is equipped with post snap lock stainless steel spring clip terminals. Silicone over fiberglass braiding covers the entire length of the wire boot to boot and provides 8000 volts of additional insulation to the wire to eliminate spark misfire and spark jump. Resists temperatures up to 600°F. Fits 1999-2017 Harley Dyna and Softail models.
Ultima #: 18-429
1999-2017 FLST
1999-2017 FXD
1999-2017 FXDWG
1999-2017 FXST
