Magneto Shaft Assembly - V-Twin 32-1210
SKU 32-1210
$159.99
$159.99 - $159.99
$159.99
The magneto shaft assembly has advance adjustment and includes four mount screws to attach to the base of the magneto head.
The mount screws for attaching the flange to the case are not included. Use 1/4 inch-20UNC or 1/4 inch-24 screws as required. The shaft assembly measures 4-5/8 inch to the bracket and 5-5/8 inch to the top of the base. Order magneto top and body separately. The hex shaft that goes into the magneto should be 3/8 inch. *NOTE: Must lubricate before assembly.
  • Suggested to use with Joe Hunt Magneto Body.
1936-1952 EL
1941-1969 FL
