Magneto Drive and Base Kit - V-Twin 32-1293 - Sportster 1936-1973
Kit will accept hex drive Magneto. Includes cast base gear pin shaft mount plate tachometer drive plug shouldered mount bolts seal and gasket.
NOTE: This is the real deal Sportster advance mechanism as the factory supplied from 1965-1970 on the XLCH models Get Real! All components as original. Must have the cast base installed as original on XLCH models. Base will accept tachometer drive gear and cable.
- Suggested to use with Magneto Base Adapter Plate.
| 1936-1973 | G |
| 1952-1956 | K |
| 1936-1952 | U |
| 1957-1970 | XL |
