Harley Pulley Brake Disc Spacer Steel 3/16 Thickness - V-Twin 19-0128 - OEM 40932-81 - Big Twin 0+
Steel 3/16 inch thick pulley and rotor spacer provides offset when required with a 7/16 inch bolt hole. The spacer measures 2 1/16 inch inner diameter with a 4 5/16 inch outer diameter. For 5 speed models. *NOTE: For 4 and 5 speed models with Mag or spoked wheels to fit 2-11/16 inch hubs. For spacing out rear sprocket rotor or pulley. The 2-1/16 inch inner diameter fits 1980-1999 FX-FL-XL hubs. Universal fit for most Harley applications.
OEM #: 40932-81
- Inner Diameter: 2-1/16 inches
- Outer Diameter: 4-5/16 inches
- Thickness: 3/16 inches
